Lenovo presents the GeForce RTX 4060 graphics card in a mini-ITX form factor. The card will initially be available in the company’s PCs, but could possibly also be available in retail stores, as is often the case with Lenovo graphics cards. Lenovo’s GeForce RTX 4060 mini graphics card is a typical mini-ITX graphics card with a length of 15 cm. It features a dual-slot cooling system and a fan. The card is based on Nvidia’s AD107 GPU, which has 3072 enabled CUDA cores. The GPU is connected to 8 GB of memory via a 128-bit bus. Additionally, the card has an 8-pin PCIe power connector. However, the exact configuration of the monitor outputs is not known.
The GeForce RTX 4060 from Nvidia is considered one of the best entry-level graphics cards, on the market and has the advantage of a comparatively low power consumption of 115W. This allows manufacturers of add-in boards to develop relatively compact products based on this graphics card. So far, only a few graphics card manufacturers have launched a mini-ITX version of the GeForce RTX 4060. Lenovo seems to be one of these manufacturers. However, we can expect other AIB designers to follow suit, as the mini-ITX form factor is ideal for a 115W GPU.
As the world’s largest PC vendor, Lenovo is not usually in the business of selling PC components. Therefore, the Mini-ITX GeForce RTX 4060 is only available as part of JD.com’s IdeaCentre GeekPro 2023 system for now. This system is based on the Intel Core i5-13400F processor and comes with 16GB of RAM and a 1TB SSD. The price starts at 6399 yen (896 euro incl. VAT, 793 euro excl. VAT). In the meantime, Lenovo graphics cards will occasionally be available in stores, so it’s possible that this card will be available separately at some point.
Source: TomsHardware
1 Antwort
