Allgemein CPU Latest news
(LEAK) Massive LGA-7529 socket for future Intel Xeon "Sierra Forest" CPUs announced
YuuKi was one of the first to publish Intel’s Sapphire Rapids engineering samples. No photos of the Sierra Forest processor have been released, but a photo of the new socket design has surfaced. However, it does not show the socket itself, but a protective cover with the inscription LGA-7529, which indicates a higher pin count than Sapphire Rapids’ 4677 design.
Source: YuuKi_AnS
The new Xeon Sierra Forest platform is part of the upcoming “Birch Stream” platform, a series of Xeon processors equipped with so-called Efficient Cores. This is a new segment of Intel’s data center CPUs that is expected to compete with AMD’s EPYC Bergamo with Zen4c cores. This “Atom”-based Xeon processor opens up Intel’s dual-track P/E core roadmap. The processors based on this silicon will exclusively use smaller cores to increase the maximum core count for these CPUs
Source YuuKi_AnS
The Sierra Forest is said by Intel to use the Intel 3 manufacturing process and be optimized for high-density and “ultra-efficient” computing in cloud systems.
Source: Intel
Recently, Intel confirmed that Sierra Forest will launch in 2024 along with Granite Rapids. This will be the first time Intel has split its Xeon lineup into P-core and E-core designs.
Source: YuuKi_AnS
Derfnam
7,517 Kommentare 2,035 Likes
Ein Glück. Endlich kein Gummisockel mehr.
R
RazielNoir
605 Kommentare 287 Likes
Puh..7529 Kontakte
Da bin ich mal auf das Verriegelungssystem gespannt.
2,440 Kommentare 1,599 Likes
Damit (Server CPU mit vielen E-Cores) hat sich Intel aber auch viel Zeit gelassen. Das, und die mehr zwei Jahre die Sapphire Rapids jetzt Verspätung hat, rächt sich wohl auch schon, denn die Umsätze bei Intel's Server CPUs sind auch ziemlich eingebrochen. Viel rote Tinte in den Bilanzen.
In einigen Szenarien sind eben viele, aber dafür effiziente Kerne die bessere Lösung. Und zumindest in Alder Lake nimmt ja ein großer Cove Kern soviel Fläche ein wie vier Gracemonts. Wenn die (zugegebenermaßen sehr vereinfachte) Rechnung aufgeht, sollte Intel hier im Vollausbau deutlich über 200 Kerne haben.
R
RazielNoir
8 Kerne in schneller sind bei dem Atom 45w TDP. Dann können auch die 200 Kerne nur langsam sein oder das Kühlsystem muss mit deutlich mehr als 250w klar kommen. Und der Interkonnekt zwischen den einzelnen Kerngruppen ist auch spannend. Hat man bei Threatripper ja schon gesehen
k
k0k0k0
136 Kommentare 63 Likes
Hat das endlich genügend Anschlüsse?
Weil alles an Boards, welche aktuell auf dem Markt erhältlich sind, sind absolut unbrauchbar!
R
RazielNoir
Meinst du Serverboards oder Workstation? Die Geräte mit dem Sockel sind wahrscheinlich kaum in den ATX-Formaten erhältlich und wenn, dann sehr sehr teuer!
k
k0k0k0
Ich rede eigentlich von Consumerboards. Aber die gibt es ja nur noch abgespeckt.
Ich brauche: 8x Sata (gern mehr), 2-3 PCIe M2, 2-3 nutzbare PCIe x1 (also nicht direkt unter dem 1. PCIex16). Gibt es nicht mehr, egal wie lange ich auf Geizhals rumfiltere.
R
RazielNoir
Ja, du schreibst aber in einer News zu einem CPU-Sockel bzw. CPU-Klasse für Server...
Samir Bashir
