Finally – an OLED monitor in 16:9 format. LG sent me the UltraGear 27GR95QE-B for testing. In addition to the well-known Ultrawide OLED options, you can now also rely on an eSports-ready format with an OLED panel. The LG 27GR95QE comes with the familiar RWBG subpixel layout and a resolution of 2560 x 1440p @ 240 Hz refresh rate ums. It’s about time!
The monitor is well packaged and set up in no time. As for the technical details, I’ve summarized the essentials for you. Everything else can be found on LG’s website. Click here!
Technical data
lg-27gr95qe-b
Everything you need is there. On the next page I’ll go into a little more detail. (Connections, cables, processing, etc.) So off we go….
166 Antworten
