AMD has added a useful feature called “System Lag” in its latest driver that allows latency monitoring in games that support Anti-Lag technology. Radeon RX 7000 GPU owners can use this feature to determine their PC’s system lag, especially when Anti-Lag is enabled. Similar to NVIDIA’s PCL feature in the FrameView application, AMD offers similar monitoring tools to its Radeon users. However, it is important to note that this feature is only available on AMD’s RDNA 3 GPUs and older RDNA architectures are not supported.
System Lag is the measured latency between when the game generates the frame and is finished rendering by the GPU. This does not include factors like display latency, which may be further increased by features like Enhanced Sync. Additionally, system lag does not include the additional latency of the frame generation from AMD Fluid Motion Frames.
The Frame Generation lag metric can be used to display this. System lag is only available when Radeon Anti-Lag is active. For Anti-Lag games that support both DirtectX11 and 12, system lag is only available with DirectX 12. System lag will be displayed as N/A when using DirectX 11.
AMD Drivers via CapFrameX
CapFrameX has found in short tests that both NVIDIA’s PC latency and AMD’s system lag in Star Wars Jedi: Survivor have similar latencies. This means that both monitoring tools work as intended and there is no discrepancy between them.
New Adrenalin overlay metric: System Lag 🔥
The feature is available with 23.30.01.02 preview driver if Radeon Anti-Lag+ is supported. The numbers looking very similar to Nvidia's PC Latency, so there must be info from the game directly (render start) to be able to cover the… pic.twitter.com/odgJHJ7Afp
— CapFrameX (@CapFrameX) October 8, 2023
To get access to the anti-lag, it is recommended to install the latest AMD Radeon preview drivers. The option can be found in the “Performance” section. The Anti-Lag technology is enabled by a switch in the driver and is currently supported in certain games.
- Apex Legends
- Overwatch 2
- Borderlands 3
- Dying Light 2
- Shadow of the Tomb Raider
- Rise of the Tomb Raider
- Resident Evil 4
- Ghostwire: Tokyo
- Fortnite
- The Last of Us: Part 1
- Star Wars Jedi: Survivor
- Forspoken
Source: CapFrameX
9 Antworten
