According to Benchlife, NVIDIA has already started testing and verifying cooling modules with capacities of up to 600W. This indicates that the most powerful “Blackwell” GPUs will consume significantly more power than the current models. However, it is important to note that these are only test versions. The final products will likely be more energy efficient and consume less power. Nevertheless, the test shows that NVIDIA is preparing for the cooling of its new GPUs. In addition to the high-performance models, NVIDIA will probably also offer more energy-efficient “Blackwell” GPUs for the mainstream market. These GPUs will likely be equipped with lower power cooling modules.
NVIDIA Testing GeForce RTX 50 Series "Blackwell" GPU Designs Ranging from 250 W to 600 W https://t.co/K8WgYHSFvM pic.twitter.com/goe1mlli63
— TechPowerUp (@TechPowerUp) May 9, 2024
The timeline for the release of the “Blackwell” GPUs is as follows
- End of Q3 2024: Unveiling of the GeForce RTX 5080 and RTX 5090 (ultra-enthusiast segment)
- Q4 20 24: Market launch of the GeForce RTX 5080 and RTX 5090
- Early 2025: Market launch of further “Blackwell” GPUs for high-end, mainstream and budget segments
It is important to note that this is only speculation and NVIDIA’s actual timeline may differ.
Conclusion:
NVIDIA is working hard to prepare for the release of its next generation of gaming GPUs. The “Blackwell” GPUs should offer a significant leap in performance compared to the current RTX 40 series, but also require more advanced cooling systems. The test of cooling modules with up to 600W power shows that NVIDIA is preparing for the cooling of its new GPUs. The first “Blackwell” GPUs are expected to hit the market at the end of this year.
Source: Benchlife, TechPowerUP
45 Antworten
