Cooling Reviews Watercooling
Sharkoon S70 and S80 all-in-one CPU compact water cooling systems Review – Almost identical, but not the same after all
Today we welcome another brand in the highly competitive market of AiO complete water coolers, as Sharkoon now also offers three models. I have often praised Sharkoon when it comes to peripherals, and you can read how the two models with 240mm radiators fared in my test in the following article. The last and larger model of the new triumvirate will follow in a separate review.
Slightly different boxes accompany our slightly different AiO water coolers, very fitting then. An inverted design distinguishes the two versions; on the S70 RGB, the front and back are white and the sides are black, while on the S80 RGB it’s the other way around.
Inside the packaging, both coolers have an identical design, a thick casing made of brown cardboard should protect the contents well during transport.
But not only the AiO itself comes in various bags, the accessories are also packed individually. Clear, but not particularly environmentally friendly. In addition to the screws and spacers for the various sockets, a short extension for a 4-pin fan connector and RGB adapters are also included.
A small tube of thermal paste is also included, none is applied ex-factory.
Assembly and installation
For the AM4 socket, the existing backplate of the motherboard is used again, but the pre-mounted plastic brackets on the front have to be removed. Four spacers are then screwed into the backplate from the front.
Then just apply thermal paste, place the pump block on the processor and tighten it with the spring-loaded screws. Wire up and let’s go!
Specifications
Here are the technical details of the entire new AiO series, more information is available on the manufacturer’s website.
LurkingInShadows
1,452 Kommentare 625 Likes
Throttelt die CPU bei 72° Delta nicht schon? Sind ja schon >=92° am Sensor....
Tim Kutzner
947 Kommentare 777 Likes
Nein, aber war knapp dran.
Sehe es in HWinfo, sollte die CPU sich drosseln.
ApolloX
1,729 Kommentare 987 Likes
Und Schande über den Hersteller, so ein Sammelsurium an Plastikfolien und Tütchen sieht man selten und muss nicht sein.
Alle Schrauben und Kleinteile in eine Folie, wenn es den schon unbedingt Folie sein muss und Radiator plus Schlauch ginge auch komplett ohne.
Also das hier bräuchte nen Anti-Nachhaltigkeitspreis.
Megaone
1,920 Kommentare 1,835 Likes
Wer kauft sowas und warum? Entweder ich mache es richtig oder kauf mir einen guten Luftkühler. Aber die Dinger kühlen weder Top noch haben sie die Lebenserwartung eines Luftkühler. Aber ist halt alles so schön so bunt hier.
Steffdeff
937 Kommentare 887 Likes
Ist man mit einem guten Luftkühler da nicht viel sorgenfreier unterwegs?
Einen echten Mehrwert kann ich, zumindest beim 240er, nicht erkennen. Mal schauen was der 360er so bringt.
Scheint ja ein riesiger Markt zu sein, denn gefühlt hat ja jeder Hardwarehersteller ne AiO im Angebot.
Bei der Verpackung hat ApolloX völlig recht!
Alternatives Verpackungsmaterial gibt es genügend.
Danke für den Test!👍
Y
Yumiko
849 Kommentare 386 Likes
Und jetzt an die Nachhaltigkeit denken, wenn die Leute wegen einem Kratzer oder einer Schraube die sie nicht finden das ganze Zurücksenden. Und ja, das sind echt viele Leute die bei Kleinigkeiten sofort zurücksenden.
Ghoster52
1,608 Kommentare 1,286 Likes
Ihr müsst es ja nicht kaufen.... ;)
Wo ein Angebot ist, wird es auch eine Nachfrage geben, nicht jeder verbaut 12 oder 16 Kerner.
Ein 5x00G ist zum Bleistift leicht zu kühlen, da dürfte das Angebot hier sicher passen.
Ist kein Handbuch dabei oder ein Plastiktütchen zu viel, schon sind die Mecker-zippen wieder unterwegs. :ROFLMAO:
Duck und wech...
Pascal TM-Custom
1,100 Kommentare 1,313 Likes
Du hast ein Denkfehler.
Solche 240er AIO sind etwas für Mini ITX Systeme meist verbaut man in so Mini ITX auch keine Highend CPU wie z.b 13900KF usw.
Daher haben solche AIO schon ihre Daseinsberechtigung
Derfnam
7,517 Kommentare 2,035 Likes
Und in welches Minihüttchen ist sowas verbaubar?
Ghoster52
In einem Focus G zum Bleistift passen nur 240er AIOs ;)
Eine 280er passt nur mit handwerkliches Geschick.
So klein müssen die Gehäus-chen gar nicht sein.
Derfnam
Joah, ich hätte anders fragen sollen. Gemeint war und ist es so: wo bietet sich diese Variante gegenüber einem Kühlturm eher an? Erfahrungswerte und so.
Mal ganz davon ab, dass das Focus G kein reines Mini-ITX-Gehäuse ist, sofern du das hier meinst: https://geizhals.de/fractal-design-focus-g-mini-schwarz-fd-ca-focus-mini-bk-w-a1629623.html
Alle anderen sind noch was größer, oder?
Pascal TM-Custom
Lian Li Q58 zb ich hab dort ja einen Custom Loop verbaut gehabt.
FritzHunter01
1,336 Kommentare 1,828 Likes
Ich verstehe es auch nicht ganz, dass man recht pauschal eine 240er AiO verteufelt. Die Kühlleistung kann man mit einem ordentlichen Luftkühler auch erreichen, keine Frage. Optisch würde ich eine 240er bevorzugen, natürlich abhängig von der zu kühlenden CPU. Einen 13900K oder 7950X mit einer 240er? Das wird schon mit einer 360er schwierig, wenn man ohne PowerLimit bzw. undervolting arbeitet.
Derfnam
Wow, 67mm Kühlerhöhe. Das rockt.
What can a poor boy do 'cept putting in a small aio 'cause in this here fucking case there's just no space for an air cooling thing...
Bitter. Und höchst albern von Lian Li.
Pascal TM-Custom
Es gibt genügend Low Profile Luft-Kühler z.b von Noctua.
In so Mini Case wie das DAN Case oder Q58 würde ich definitiv eine 240er AIO einbauen wenn es schon möglich ist.
Besonders da man hier eine Art Doppelkammer System hat.
5800x rein mit AIO und auf der anderen Seite 3080 rein unter Luft. Da hat man auf engsten Raum ein Performantes System.
Derfnam
Und das ist ein gutes Sinnbild für alles, was gerade falsch läuft. So viel Freizeit wie möglich, so viel Freiraum und dann wird alles in so winzige Mistdinger gekrampft. Weil es geht, ne? Und so individuell ist wie damals des Modders Blingi. Fuck that. All of it.
Derfnam
Zu melodramatisch, ne?
Pascal TM-Custom
Für was gibt es itx? iTX ist eben genau für sowas da. Ich hab in das kleine Ding ganzen Custom Loop bekommen oder im NR200P.
Gedanken Anstoß Braucht man unbedingt ATX? Wenn man nur einen PCIe Slot belegt mit einer GPU und sonst keinen weiteren Verbraucher?
Meine Antwort NEIN ich hab weder Einschränkung mit RAM gibt ja auch 16er oder 32 Kita Pro Riegel. M2 gibt es auch mit ordentlicher Größe und die kleinen Boards haben eine gute Ausstattung mit USB usw.
Also warum nicht auf kleinsten Raum etwas schönes Bauen?
ITX ist mega, mit gescheiter Planung steht man einem ATX in nichts nach und braucht man doch weiteren Slot geht man auf M-ATX.
Daher sind so kleine AIO und Case Spitze.
Derfnam
Mit meinen Wurstfingern kann das Geraffel gar nicht groß genug sein. Und gut viel Platz nehm ich auch richtig gerne. Im alten Forum hatte sich alterSack66 die Lian Li-Lok zugelegt und geflucht wie n Rohrspatz, weil das alles so extrem frickelig war.
Gibt alle Sorten, nicht vergessen. Ich kann mit dem Winzkrempel nichts anfangen, ich lehne Wasser im Gehäuse und auch nur in der Nähe des PCs ab. Für mich ist sowas weder mega noch Spitze. Gescheite Planung bedeutet für mich und viele andere Grobmotoriker - innen wie außen -, darauf zu achten, dass ich Platz habe fürs Frickeln.
ITX ist für mich dazu da, mir jegliche Freude am PC-Zusammenbau zu nehmen.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
