CPU Latest news Motherboard
Ready for the next CPU generation? ASUS equips AM5 motherboards for Ryzen 9000
ASUS is the second motherboard manufacturer to confirm the compatibility of the upcoming AMD Ryzen 9000 “Zen 5 Granite Ridge” CPUs with AM5 motherboards, according to our colleagues at Hardwareluxx. ASUS already released a BIOS update with the AGESA version 1.1.7.0 for its AM5 mainboards at the beginning of this month. Although the changelogs for this update only vaguely mentioned support for “future CPUs”, ASUS has now officially confirmed compatibility with the Ryzen 9000 processors, as reported by HXL (@9550pro). This means that owners of AM5 motherboards from ASUS can upgrade as soon as the Ryzen 9000 CPUs come onto the market in the second half of 2024.
Source: AMD
Which ASUS AM5 mainboards are supported?
The following list shows all ASUS AM5 (X670E) motherboards that have received the AMD AGESA 1.1.7.0 BIOS update with Zen 5 support:
  • ROG CROSSHAIR X670E HERO BETA BIOS 2003
  • ROG CROSSHAIR X670E GENE BETA BIOS 2003
  • ROG CROSSHAIR X670E EXTREME BETA BIOS 2003
  • ROG STRIX X670E-A GAMING WIFI BETA BIOS 2003
  • ROG STRIX X670E-E GAMING WIFI BETA BIOS 2003
  • ROG STRIX X670E-F GAMING WIFI BETA BIOS 2003
  • ROG STRIX X670E-I GAMING WIFI BETA BIOS 2603
Source: HardwareLUXX
More details on Ryzen 9000 support:
  • The support refers to the “AMD Ryzen” Granite Ridge family and extends the SMU to 98.58.0.
  • The AMD Granite Ridge family is also identified by the “00B40Fxx” ID.
  • Initial engineering samples of the Zen 5 “Ryzen” CPUs are already in use by motherboard manufacturers.
  • The official unveiling of the Ryzen 9000 CPUs is expected at Computex 2024 in early June.
What are the benefits of Zen 5?
The Zen 5 architecture from AMD promises:
  • Improved performance and efficiency
  • Restructured front-end and wide output
  • Integrated AI and machine learning optimizations
Buying an AM5 motherboard now is a future-proof investment, as these motherboards are already equipped for the next generation of powerful AMD Ryzen 9000 “Zen 5 Granite Ridge” CPUs.
Source: Hardwareluxx, HXL (@9550pro)
Lantis1986
53 Kommentare 23 Likes
Wann kommen denn die Ryzen 9000 X3D eigentlich?
arcDaniel
1,787 Kommentare 1,032 Likes
Was ich interessant finde und wo man keine Details darüber findet ist, dass mit AGES 1.1.7.0 auch Ryzen 7000 eine neue SMU bekommt:
Quelle:
a
alexk94
3 Kommentare 4 Likes
Wenn du Glück hast am Ende des Jahres. Wenn du Pech hast es wäre Anfang des Jahres während der CES 2025.
Antwort 4 Likes
arcDaniel
Die Normalen sollten eigentlich nach den Sommerferien kommen und die 3D erst Ende dieses Jahres Anfang nächstes und werden als Antwort auf Arrow Lake gehandelt.
ElchDerImKreisRennt
17 Kommentare 4 Likes
Also wenn die 9000er dann auch vernünftig auf den X670E vernünftig laufen und nicht zwangsweise dann ein X770(?) benötigt samt vernünftiger RAM Unterstützung, bin ich auf jeden Fall gespannt auf die nächste Gen X3D CPUs!
amd_24
19 Kommentare 3 Likes
Zu diesem Zeitpunkt warte ich auch auf die Nachfolger 3D Cache CPUs, wobei der 7800X3D preislich in gute Regionen vorgestoßen ist. Bin guter Dinge, dass AMD den 3D Pendanten nicht zu allzu lang "zurückhält". Der Cache zaubert in Gaming-Szenarien (des Öfteren in schlecht optimierten Spielen) und macht RAM-Speed bzw. Optimierung quasi irrelevant.
f
fwiener
82 Kommentare 51 Likes
Ich hoffe, die neuen 9000er x3D kommen spätestens kurz nach der CES '25, also noch vor dem nächsten Sommer. September wäre aber auch nicht schlecht, da zu der Zeit die Preise normalerweise kräftig anfangen zu sinken - das würde dann die Vorgängermodelle samt kompatibler Hardware deutlich erschwinglicher machen.
Aber wer weiß, vielleicht explodiert ja mal wieder eine Chipfabrik oder jemand verschüttet Kaffee auf die Präzisions-Belichtungsmaschinen oder China annektiert Taiwan...
F
FreedomOfSpeech
7 Kommentare 1 Likes
Der 9800x3d lohnt sich erst mit RTX 5090 und 240Hz Monitor. Dann muss ich ja 3x aufrüsten ;-)
amd_24
Joa. Im Prinzip hast du recht. Allerdings kann die CPU nie schnell genug sein in Hinblick auf z. B. eSports Titel oder auch casual-FPS Spielen. Bei 1440p & 1080p limitiert dann doch immer noch die CPU, anstatt der 4090.
Für neuere OLEDs mit 480Hz und TN 540Hz ist jedes Leistungsplus bei der CPU willkommen (auch dank DLSS und FSR, die den Flaschenhals von GPU in Richtung CPU verschieben durch niedrigere Renderauflösung). :D
Markusgo1967
14 Kommentare 5 Likes
Ich warte auf die Benchmarks und wenn es dann wirklich Sinn macht, schicke ich meine 5800x3d in Rente.
q
querulant
56 Kommentare 37 Likes
Die x3d-Versionen kamen bisher immer erst nach den Nicht-x3d-Versionen. Also erst mal den Start der 9000er-Reihe abwarten.
arcDaniel
Ich bin auf die neuen X3D gespannt ob und es im Scheduling Verbesserungen gibt und/oder CPUs mit 2x V-Cache.
Bei denn 7000er ist es ja so, dass ich die Wahl habe eine Gaming CPU den 7800X3D zu nehmen oder mehr Leistung in Anwendungen haben möchte mit einem 79(5)0.
Die 79(5)0X3D CPUs sind hier nicht wirklich optimal. In Anwendungen bringt der V-Cache fast nix und man ist wegen geringerem Takt meist im Nachteil. Spiele, naja manche Vertragen die Aufteilung gut andere nicht so. Und für jedes Spiel immer einen Modus Preferred Cache oder Preferred Frequencies wählen zu müssen, nervt auch.
Was im Allgemeinen den V-Cache aber angeht, dieser beseitigt ja aktuell eher Flaschenhälse und wer weiß, vielleicht ist Zen5 hier ja so verbessert, dass der Unterschied im Gaming geringer ist.
q
querulant
Scheduling müsste eigentlich allein schon deshalb besser werden, weil pro Chiplet nicht mehr "nur" 8 Cores sind, sondern bis zu 16. D.h. man hat 16 Cores auf einem Die und damit sind die Latenzen eher besser (klar dass er ja nicht immer zwischen den Dies herum springen muss). Wenn wir an den 7950X3D und 7900X3D denken, profitieren künftig wohl auch alle Cores vom 3D-Cache, und nicht bloß 50% der Cores. 7800X3D war wohl auch deshalb so verteufelt gut, weil hier das Scheduling einfacher war. Ein effizienter 9800X3D mit 16 Cores auf einem Die mit mindestens 96MB Cache wär lässig - da können Intel's Stromfresser einpacken.
Don Esteban
17 Kommentare 2 Likes
So schnell muss der Gute noch nicht in Rente, im 5800x3d steckt noch ordentlich Leben und im Gaming wird er, so weit ich weiß, nur von den 7000er x3d ein bisschen und von intels i9 13. und 14. Gen knapp übertroffen.
q
querulant
Womöglich kommt vorher noch ein "Ryzen 9 7950X3D² mit doppeltem 3D V-Cache": https://www.pcgameshardware.de/Ryze...le-mit-3D-V-Cache-auf-beiden-Chiplets-1446821
9000er-Serie mit 3D-Cache kommt evtl. bei der CES 2025.
arcDaniel
Es wurde schon bestätigt, dass es nur ein Auslesefehler ist, welcher reproduzierbar ist.
Samir Bashir
