Reviews SSD & HDD Storage Storage drives
BIWIN HP SSD EX950 M.2 2TB Review – TLC in fast and cost-effective
There’s no need to repeat the war of the clone SSD sheeps with nearly identical Techvest boards, because if you know one, you know all SSDs. Well, yeah, more or less. And then BIWIN comes now with the HP SSD EX950 M.2 2TB from 240 euros and a different design and nice prices. This is even cheaper than a QLC-SSD in the form of the already tested Corsair MP400, which is certainly suitable for permanently stored data, but technically not for a daily fast data transfer. The 2 TB for around 240 Euro with a proper brand also on the sticker are a fair offer, by the way, the test against the Corsair MP400 will show that later.
BIWIN who? You are welcome to have a look at the BIWIN homepage, I will of course refrain from enumerating propaganda. However, as an up-and-coming market player, BIWIN has serious ambitions to bring decent storage products to the market, because the HP logo also commits to a certain level of performance. HP is not a slingshot brand and something must have been thought of there as well, since they are one of the best known PC manufacturers.
But although the company is very broadly positioned, they had almost nothing to offer in the SSD sector. The first, serious attempt by HP itself to offer a consumer SSD for retail ended rather modestly four years ago. Then, with BIWIN and the HP SSD EX920, they suddenly had a product at the start, which relied on a controller from Silicon Motion and Micron’s 64L 3D TLC flash with the SM2262 and already performed quite passably. And now BIWIN is trusted again and releases the whole thing as a completely new line-up to the buyers. The SSD is available in 512 GB, 1 TB and 2 TB sizes.
Unlike some competitors, however, the HP SSD EX950 does not support hardware encryption and does not offer software in the form of an SSD toolbox, but it does at least support secure erasure. Additionally, BIWIN includes a screw to secure the M.2 SSD, just in case the user is scatterbrained and has scrapped the original screw.
But back to the SSD. It is interesting that BIWIN gives a 5-year warranty or until the TBW of 1400 TBW is reached. The SSD tested today also has a SMI SM2262EN from Silicon Motion in disguise, but branded to HP (H8088). The controller is not brand new, but still up to date. The PCB design and a once again optimized firmware are also important here. 2x 1GB GB Micron DDR3 DRAM promote the performance, 4 modules with 64-layer 3D TLC NAND provide secure storage. These modules are manufactured at BIWIN and only the wafers (Micron) are purchased. Packaging and labeling are now done by BIWIN itself.
The SSD comes without a cooler, but the controller’s heatspreader gets a bit warmer, but not hot yet. The measured power consumption of just under 3 watts on average is good, but I still recommend cooling (at least the controller) in extensive use. That’s all I need to say now, and before I get to the benchmarks on the next page, I of course have the datasheet as an original PDF for you:
Simplified Datasheet for EX950 M.2_EN
konkretor
318 Kommentare 325 Likes
Klassiches OEM Produkt
Preis und Performance passen, 1400 TBW sind eine Ansage
Crucial ist mit seiner P2 SSD 2 TB bei nur 600 TBW
Case39
2,573 Kommentare 983 Likes
Das war jetzt interessant. Danke für das Review👍
D
Denniss
1,627 Kommentare 609 Likes
Bei Crucial wäre die P5 vergleichbar und die hat 1200 TBW
Timberwolf
33 Kommentare 13 Likes
Als Kauftipp würde ich eher die baugleichen NVMe SSD von Mushkin und ADATA nennen, welche auch noch 256Bit AES Hardwareverschlüsselung bieten und seit längerem auch deutlich günstiger zu erstehen sind:
Mushkin Pilot-E 2TB (MKNSSDPE2TB-D8)
ADATA XPG Gammix S11 Pro 2TB, M.2 (AGAMMIXS11P-2TT-C)
Klar die Muskin kommt mit einer kürzeren Herstellergarantie von nur 3 Jahren und keiner Software-Toolbox daher, aber es ist auch nicht außer acht zu lassen, dass man diese bereits schon deutlich unter 200€ erwerben konnte, was für eine 2TB NVMe mit DRAM Cache und TLC NAND schon mehr als nur ordentlich ist. Wie viel einem die zusätzliche Garantiedauer wert ist, ist natürlich jedem selbst überlassen.
Ansonsten wäre auch noch die ADATA XPG SX8200 Pro Modellreihe zu nennen, welche am Anfang ebenfalls auf das besagte Design mit dem Silicon Motion SM2262EN Controller gesetzt hat. Aktuell sind diese leider nicht mehr empfehlenswert, da ADATA ganz klamm und heimlich den Controller und den NAND ausgetauscht hat, was nun zur Folge hat, dass jetzt mehrere sich deutlich in der Leistung unterscheidende Revisionen am Markt sind: Not-So-Solid State: SSD Makers Swap Parts Without Telling Us
grimm
3,229 Kommentare 2,168 Likes
Ja, passt. Danke für den Test. Ich bin auf der Suche nach einer P/L Storage-Lösung als Datengrab (Bilder, Filme, Doks). Die hier ist ja fast schon zu schade, weil schnell.
Timberwolf
Dann würde ich empfehlen bei der Crucial P1 SSD 2TB (CT2000P1SSD8), sofern diese wieder im Angebot ist, zu zu schlagen. Diese ist immer wieder mal bei diversen Aktionen für um die 140-160 Euro zu haben: klick
Für den angedachten Einsatzzweck dürfte der QLC Speicher, mit seinen bekannten Vor und Nachteilen, trotzdem ausreichend sein.
D
Denniss
Die Vorteile von QLC (Preis) sind eher ab 4TB spürbar, bei kleineren Varianten obliegen eher die Nachteile da dort kaum ein günstigerer Preis vorkommt.
10,834 Kommentare 20,527 Likes
Naja, nicht ganz. BIWIN fertig die Module mittlerweile selbst und kauft die Wafer zu.
Die Adata würde ich jetzt auch nicht mehr kaufen. Stichwort Clone-Warrior. Die war echt mal ein Tipp und ist jetzt die übliche Hama-Wundertüte. :D
konkretor
Danke Igor für das Detail, wenn sie die Wafer beziehen und dann selber schneiden und das Packaging machen dann ist natürlich kein OEM mehr.
BIWIN hat sich mittlerweile eine eigene Factory hingezimmert. Da wird gescheit expandiert. :D
(Ich hatte ja auch den Link zur Herstellerseite mit im Text)
S
Snakeisthestuff
55 Kommentare 36 Likes
Mal zum Vergleich der CrystalDiskMark von meiner neuen Samsung PM9A1 2TB im PCIE 3.0 x4 slot:
Interessant dass die 4KiB Q32T1 Werte bei mir so viel niedriger sind. Limitiert da evtl. meine CPU (2950x) oder liegt das an einer unterschiedlichen Optimierung im Controller?
Anderer Controller, andere Prämissen in der Firmware. Ich mage die Synthetics eh nicht sonderlich, wichtig ist auf dem Platz :)
Timberwolf
Selbst bei den diversen Iterationen der NVMe SSDs mit Silicon Motion SM2262EN Controller, welche von außen quasi fast identisch aussehen, gibt es recht deutliche Unterschiede Leistungsunterschiede. Dies ist je nach Hersteller der etwas anders abgestimmten Firmware für den SM2262EN geschuldet.
Sehr schön zu sehen wenn man sich den Testbericht der ADATA XPG Gammix S11 Pro, in dem auch die ADATA XPG SX8200 Pro und die Mushkin Pilot-E im Vergelich gelistet werden, sowie den Test der HP SSD EX950 vergelicht.
H
Headyman
117 Kommentare 54 Likes
Schöner Test und interessante SSD, Danke
solche Relabels fallen gerne mal aus dem Raster.
Eine Anmerkung noch:
Der Satz: "...das Lesen ist nicht mehr ganz so schnell..."
passt nicht, denn es suggeriert einen deutlichen Einbruch, der aber bezüglich der erwähnten 3500MB/s bei nur 0,34% liegt.
Die Messungenauigkeiten dürfte Faktoren größer sein...
Ich war mit der Jungfräulichen immer etwas über 3500 MB/s, insgesamt 5 Runs. Und dann mit der Gerbrauchten immer etwas drunter, auch 5 Runs. Die Differenz ist reproduzierbar. Aber sehr groß ist sie nicht :)
S
Schemmi
5 Kommentare 1 Likes
Wäre ein gutes Upgrade, der Preis ist heiß 😁
Ich finde den Preis interessant. Und es ist eben mal nicht das übliche Toshiba/Phison Gemisch, das es zu Hauf gibt.
Shakj
18 Kommentare 19 Likes
Hab mir das Ding mal geholt. Läuft gut und wird nicht warm bzw. fängt sich fix wieder. Eine Info noch für etwaige Käufer des Teils: Das Ding hat drolligerweise 2 rote unfassbar helle Aktivitäts-LEDs unter dem weißen Sticker, die munter vor sich hin blinken. :)
Die betreibt man ja eh einbgebaut mit Kühler ;)
Follow Igor:
