Before angry comments are made in the forum that a Celeron CPU also has its raison d’être: The title of this article is to be understood with a wink. However, we still check whether a processor from Intel’s lower drawer paired with Windows 11 is suitable for everyday use.
The last mini-PC with an N-CPU was not quite convincing in terms of performance. But he was also smaller than any other, more about that here:
ECS Liva Q1L Mini-PC Review – Tiny thanks to sandwich design
This system comes in Beelink’s new cuboid box and, aside from a few blueb accents, has a white design.
Two layers of cardboard protect the sides, from the top and bottom a thin layer of foam takes over the transport protection.
The accessories consist of a short manual, the power adapter as well as VESA mount and two HDMI cables.
Length of the cables is 20cm and 100cm, respectively, convenient when the computer hangs directly on the monitor or is placed on the desk.
Specifications
Here is an overview of the technical details, more information is available on the product page from the manufacturer.
7 Antworten
