ASUS has unveiled an extension to the Noctua edition range of GeForce RTX 30 and RTX 40 series GPUs to coincide with today’s launch at 3pm. The next GPU is based on NVIDIA’s flagship RTX-40 SUPER cards, the GeForce RTX 4080 SUPER. Although it is not in today’s test, two other cards are.
![](https://www.igorslab.de/wp-content/uploads/2024/01/fwebp-980x980.webp)
ASUS has once again collaborated with Noctua to develop the GeForce RTX 4080 SUPER Noctua OC Edition. This graphics card offers premium GPU cooling and performance, including massive quad-slot cooling with two Noctua NF-A12x25 PWM fans, dual BIOS design, 0db fan technology and overclocking of up to 2640 MHz. This corresponds to a boost of 3.5 % compared to the reference clock frequency of 2550 MHz.
- OC Edition: 2640 MHz (OC mode)/2610 MHz (standard mode).
- Two Noctua NF-A12x25 PWM fans ensure exceptional cooling and low noise levels.
- An optimized vapor chamber efficiently dissipates heat into a large fin array.
- The dual BIOS switch makes it possible to switch between the “Quiet” and “Performance” BIOS profiles without software.
- The 0 dB technology enables relaxed gaming in relative silence.
- GPU Tweak III offers intuitive performance customization, thermal controls and system monitoring.
Other additional functions include five display outputs, including two HDMI 2.1 and three DisplayPort 1.4 outputs. You can easily switch between power mode and sleep mode with the dual BIOS, which is located on the back for easy access. There is also a small cut-out on the back through which the second fan can blow air.
Similar to the previous versions, ASUS will also use a customized PCB design for the GeForce RTX 4080 SUPER Noctua OC Edition graphics card, which will be offered at a premium price. The card is particularly suitable for users who want maximum cooling performance with minimum noise. With the launch of the NVIDIA RTX 4080 SUPER GPUs today, we will be able to track and report on the price development of this graphics card.
Source: Momomo_US
40 Antworten
