Tested maps and links to the individual reviews
In the following, we list all our extensive individual reviews for the GeForce GTX 1080 Ti, which score above all in terms of technical features and the details of the implementation in production. So if you want to go into the depths in addition to the comparative evaluations of this summary, you are of course invited to do so:
09.03.2017 | Nvidia GeForce GTX 1080 Ti Founders Edition |
13.03.2017 | Water cooling conversion GeForce GTX 1080 Ti Founders Edition |
02.05.2017 | Aorus GeForce GTX 1080 Ti Xtreme Edition 11G |
25.07.2017 | Asus GeForce GTX 1080 Ti Poseidon Platinum |
12.09.2017 (NEW) |
Asus GeForce GTX 1080 Ti Strix OC |
10.05.2017 | Evga GeForce GTX 1080 Ti FTW3 Gaming |
23.05.2017 | KFA2 / Galax GeForce GTX 1080 Ti EXOC |
13.06.2017 | KFA2 / Galax GeForce GTX 1080 Ti HoF (Hall of Fame) |
20.04.2017 | Msi GeForce GTX 1080 Ti Gaming X 11G |
17.10.2017 (NEW) |
Msi GeForce GTX 1080 Ti Gaming X Trio |
01.08.2017 | Msi GeForce GTX 1080 Ti Lightning Z |
03.07.2017 | Palit GeForce GTX 1080 Ti SuperJetstream |
04.05.2017 |
Zotac GeForce GTX 1080 Ti Amp! Extreme Edition |
Continuing…. |
Short overview of all tested maps
At this point we have summarized the most important general technical data in tabular form, which are the same for all tested maps:
Nvidia Titan X – (Pascal) Mr President, I would like to |
Nvidia Geforce GTX 1080 Ti FE |
Nvidia Geforce GTX 1080 FE |
Nvidia Geforce GTX 980 Ti |
Gpu |
GP102 | GP102 |
GP104 | GM200 |
CUDA cores |
3584 | 3584 |
2560 | 2816 |
Memory Size & Type |
12 GByte GDDR5X |
11 GByte GDDR5X |
8 GByte GDDR5X |
6 GByte GDDR5 |
The size |
471 mm2 | 471 mm2 |
314 mm2 | 601 mm2 |
Technology |
16 nm | 16 nm |
16 nm | 28 nm |
Transistors |
12 billion | 12 billion |
7.2 billion | 8 billion |
Streaming Multiprocessors (SM) |
28 | 28 |
20 | 22 |
Texture Units |
224 | 224 |
160 | 176 |
Rops |
96 | 88 | 64 | 96 |
Storage data rate |
10 Gbps | 11 Gbps | 10 Gbps | 7 Gbps |
Storage bus |
384 bits | 352 bits |
256 bits | 384 bits |
Memory bandwidth |
480 GByte/s | 484 GByte/s |
320 GByte/s | 336 GByte/s |
L2 cache |
3 MByte | 2816 KByte |
2 MByte | 3 MByte |
Tdp |
250 watts | 250 watts |
180 watts | 250 watts |
In addition, of course, there are the data that differ from each other in the maps tested. These values can be found in the following table, as well as in the following pages with the comparisons. However, in the table below, we have recorded everything that cannot be recorded in bar graphs for the benchmark and measurement results:
Test system and measurement methods
The new test system and the methodology have already been described in great detail in the basic article "How We Test Graphics Cards" (English: "How We Test Graphics Cards") and therefore, for the sake of simplicity, we now only refer to this detailed Description. So if you want to read everything again, you are welcome to do so. However, we have improved CPU and cooling once again in order to largely exclude possible CPU bottle necks for this fast card.
If you are interested, the summary in table form quickly provides a brief overview:
Test systems and measuring rooms | |
Hardware: |
Intel Core i7-6900K -4.3GHz MSI X99S XPower Gaming Titanium Corsair Vengeance DDR4-3200 1x 1 TByte Toshiba OCZ RD400 (M.2, System SSD) 2x 960 GByte Toshiba OCZ TR150 (Storage, Images) Be Quiet Dark Power Pro 11, 850-watt power supply Windows 10 Pro (all updates) |
Cooling: |
Alphacool Ice Block XPX Alphacool Ice Age 2000 Chiller 2x Be Quiet! Silent Wings 3 PWM (Closed Case Simulation) Thermal Grizzly Kryonaut (for cooler change) |
Housing: |
Lian Li PC-T70 with expansion kit and modifications Modes: Open Benchtable, Closed Case |
Power consumption: |
non-contact DC measurement on the PCIe slot (Riser-Card) non-contact DC measurement on the external PCIe power supply Direct voltage measurement on the respective feeders and on the power supply 2x Rohde & Schwarz HMO 3054, 500 MHz multi-channel oscillograph with memory function 4x Rohde & Schwarz HZO50, current togor adapter (1 mA to 30 A, 100 KHz, DC) 4x Rohde & Schwarz HZ355, touch divider (10:1, 500 MHz) 1x Rohde & Schwarz HMC 8012, digital multimeter with storage function |
Thermography: |
Optris PI640, infrared camera PI Connect evaluation software with profiles |
Acoustics: |
NTI Audio M2211 (with calibration file) Steinberg UR12 (with phantom power for the microphones) Creative X7, Smaart v.7 own low-reflection measuring room, 3.5 x 1.8 x 2.2 m (LxTxH) Axial measurements, perpendicular to the center of the sound source(s), measuring distance 50 cm Noise in dBA (Slow) as RTA measurement Frequency spectrum as a graph |
