Since there were some irritations at the beginning, also in connection with older installations, a special CTR-Cleaner is now available for download, which deletes the old entries from the registry under ” %LOCALAPPDATA%/A, %LOCALAPPDATA%/Nemesis_UIv2″ reliably.
Please note: The program should be run as administrator (right click and “Run as administrator”). Then all values are reset to the initial status. The ZIP archive contains an executable file that may be detected as a threat due to registry access. But you can ignore that as long as the ZIP archive is downloaded from our server.
