Corsair
Noctua
QL120 RGB
NF-A14 FLX
163 g
210 g
500 U/min
900 U/min
1500 U/min
1200 U/min
41.8 CFM
68.0 CFM
115.5 m³/h
1.55 mmH2O
1.51 mmH2O
26.0 dBA
19.2 dBA
Beige
Silber
Braun
Halbtransparent
Braun
3.0 V
4.6 V
4.2 V
245 U/min
381 U/min
472 U/min
469 U/min
1600 U/min
1199 U/min
27.8 CFM
+92.6 %
53.5 CFM
20.6 CFM
+60.0 %
33.0 CFM
19.2 CFM
+65.1 %
31.7 CFM
17.2 CFM
+74.8 %
30.1 CFM
47.2 m³/h
+92.6 %
90.9 m³/h
35.0 m³/h
+60.0 %
56.0 m³/h
32.6 m³/h
+65.0 %
53.8 m³/h
29.3 m³/h
+74.7 %
51.2 m³/h
1.01 mmH2O
+11.0 %
0.91 mmH2O
+82.0 %
0.91 mmH2O
0.5
0.5
0.40 mmH2O
+33.3 %
0.30 mmH2O
+11.1 %
0.09 hPa
+80.0 %
0.09 hPa
0.05
0.05
+33.3 %
0.03 hPa
38.4
-10.9 %
34.2
38.3
-10.1 %
42.6
35.9
-12.0 %
40.8
35.8
-10.3 %
39.9
