Blacknoise
Alphacool
NB-eLoop X PWM B12xP ARGB
Rise Aurora
120 g
180 g
Grau
3.4 V
3.0 V
2.9 V
294 U/min
862 U/min
138 U/min
874 U/min
339 U/min
181 U/min
2002 U/min
2775 U/min
1045 U/min
40.5 CFM
+39.8 %
29.0 CFM
24.9 CFM
+1.9 %
24.4 CFM
23.0 CFM
+2.0 %
23.5 CFM
21.0 CFM
+5.0 %
22.1 CFM
68.9 m³/h
+39.8 %
49.3 m³/h
42.3 m³/h
+1.9 %
41.5 m³/h
39.1 m³/h
+2.0 %
39.9 m³/h
35.7 m³/h
+5.0 %
37.5 m³/h
1.43 mmH2O
+133.7 %
+58.9 %
0.51 mmH2O
+49.5 %
0.41 mmH2O
+22.6 %
0.41 mmH2O
0.14 hPa
+133.3 %
+60.0 %
+50.0 %
+25.0 %
34.4
-17.3 %
41.6
36.5
-11.0 %
41
35.9
-8.2 %
39.1
36.1
-10.9 %
40.5
