Lian Li
Thermalright
UNI FAN SL120 ARGB
TL-B12 Extreme
25.6 mm
232 g
215 g
800 U/min
550 U/min
1900 U/min
3150 U/min
1.0 W
4.2 W
58.5 CFM
112.0 CFM
99.5 m³/h
190.3 m³/h
1.67 mmH2O
5.00 mmH2O
31.0 dBA
40.5 dBA
Silber
Rot, Weiß
1.8 V
2.4 V
1.4 V
412 U/min
293 U/min
98 U/min
163 U/min
1828 U/min
2857 U/min
554 U/min
23.2 CFM
+36.0 %
31.6 CFM
17.7 CFM
+33.9 %
23.7 CFM
15.8 CFM
+40.9 %
22.3 CFM
15.3 CFM
+37.7 %
21.1 CFM
39.5 m³/h
+35.9 %
53.7 m³/h
30.1 m³/h
+33.9 %
40.3 m³/h
26.9 m³/h
+40.9 %
37.9 m³/h
26.0 m³/h
+37.7 %
35.8 m³/h
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+77.5 %
+75.0 %
+75.0 %
+100.0 %
+75.0 %
38.8
-16.5 %
32.4
36.7
-15.3 %
31.1
36.1
-10.0 %
32.5
34.6
-11.8 %
30.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
