Lian Li
Sharkoon
UNI FAN SL120 ARGB
Silent Storm PWM RGB Fan
232 g
135 g
800 U/min
400 U/min
1900 U/min
1400 U/min
2.2 W
58.5 CFM
99.5 m³/h
93.6 m³/h
1.67 mmH2O
31.0 dBA
20.4 dBA
Silber
3.6 V
2.4 V
412 U/min
585 U/min
98 U/min
561 U/min
1828 U/min
1374 U/min
513 U/min
23.2 CFM
+46.3 %
34.0 CFM
17.7 CFM
+10.0 %
19.5 CFM
15.8 CFM
+54.3 %
24.4 CFM
15.3 CFM
+40.8 %
21.5 CFM
39.5 m³/h
+46.3 %
57.8 m³/h
30.1 m³/h
+10.0 %
33.1 m³/h
26.9 m³/h
+54.3 %
41.5 m³/h
26.0 m³/h
+40.8 %
36.6 m³/h
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+75.0 %
+50.0 %
+50.0 %
+50.0 %
38.8
-18.3 %
31.7
36.7
-20.4 %
29.2
36.1
-23.8 %
27.5
34.6
-21.7 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
