Arctic
Fractal
P14 PWM
Prisma AL-12PWM
194 g
167 g
200 U/min
500 U/min
1700 U/min
1.9 W
72.8 CFM
85.7 CFM
123.8 m³/h
145.7 m³/h
2.40 mmH2O
2.80 mmH2O
32.0 dBA
3.8 V
4.5 V
3.8 V
395 U/min
443 U/min
481 U/min
269 U/min
1733 U/min
2001 U/min
550 U/min
45.7 CFM
+44.5 %
31.6 CFM
27.1 CFM
+30.7 %
20.7 CFM
25.8 CFM
+23.7 %
20.8 CFM
27.0 CFM
+36.6 %
19.8 CFM
77.6 m³/h
+44.5 %
53.7 m³/h
46.0 m³/h
+30.7 %
35.2 m³/h
43.8 m³/h
+23.7 %
35.4 m³/h
45.9 m³/h
+36.6 %
33.6 m³/h
0.60 mmH2O
+35.0 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
+33.3 %
+75.0 %
+75.0 %
+50.0 %
30.7
-13.5 %
35.5
30.4
-9.5 %
33.6
30
-6.0 %
31.9
30.6
-6.5 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
