Cooler Master
EK
Sickleflow 140 ARGB
Vardar X3M D-RGB
27.5 mm
195 g
210 g
650 U/min
500 U/min
1400 U/min
2200 U/min
2.2 W
67.0 CFM
67.0 CFM
113.8 m³/h
114.0 m³/h
2.25 mmH2O
2.75 mmH2O
27.0 dBA
34.2 dBA
Halbtransparent
5.5 V
2.7 V
2.9 V
2.3 V
599 U/min
472 U/min
495 U/min
418 U/min
666 U/min
367 U/min
1374 U/min
2161 U/min
45.3 CFM
+24.4 %
36.4 CFM
28.1 CFM
+28.6 %
21.8 CFM
26.1 CFM
+28.0 %
20.4 CFM
27.0 CFM
+40.8 %
19.2 CFM
77.0 m³/h
+24.4 %
61.9 m³/h
47.7 m³/h
+28.6 %
37.1 m³/h
44.3 m³/h
+28.0 %
34.6 m³/h
45.9 m³/h
+40.8 %
32.6 m³/h
+164.0 %
1.32 mmH2O
+22.0 %
0.5
0.5
+22.0 %
+160.0 %
0.13 hPa
+20.0 %
0.05
0.05
+20.0 %
35.5
-15.8 %
29.9
37.2
-9.1 %
33.8
32.8
-13.7 %
28.3
33.5
-15.2 %
28.4
  • 666
  • 866
  • 1066
  • 1266
  • 1466
  • 1666
  • 1866
  • 2066
