Cooler Master
Alpenföhn
Sickleflow 140 ARGB
Wing Boost 3 ARGB High Speed
195 g
208 g
650 U/min
500 U/min
1400 U/min
2200 U/min
4.1 W
67.0 CFM
77.9 CFM
113.8 m³/h
132.4 m³/h
2.25 mmH2O
3.24 mmH2O
27.0 dBA
36.8 dBA
Silber
Halbtransparent
5.5 V
2.7 V
2.9 V
2.5 V
599 U/min
485 U/min
495 U/min
302 U/min
1374 U/min
2281 U/min
458 U/min
45.3 CFM
+38.3 %
32.8 CFM
28.1 CFM
+34.8 %
20.8 CFM
26.1 CFM
+34.2 %
19.4 CFM
27.0 CFM
+50.5 %
17.9 CFM
77.0 m³/h
+38.2 %
55.7 m³/h
47.7 m³/h
+34.7 %
35.4 m³/h
44.3 m³/h
+34.2 %
33.0 m³/h
45.9 m³/h
+50.5 %
30.5 m³/h
+266.0 %
1.83 mmH2O
+246.0 %
1.73 mmH2O
+246.0 %
1.73 mmH2O
+102.0 %
1.01 mmH2O
+260.0 %
0.18 hPa
+240.0 %
0.17 hPa
+240.0 %
0.17 hPa
+100.0 %
35.5
-13.2 %
40.9
37.2
-8.1 %
40.5
32.8
-15.9 %
39
33.5
-10.7 %
37.5
  • 302
  • 502
  • 702
  • 902
  • 1102
  • 1302
  • 1502
  • 1702
  • 1902
  • 2102
