Blacknoise
B12x-PS-BL PWM ARGB
Silent Wings 3
120 g
137 g
150 U/min
1500 U/min
1450 U/min
58.1 CFM
50.5 CFM
98.7 m³/h
85.8 m³/h
1.80 mmH2O
1.79 mmH2O
21.2 dBA
16.4 dBA
3.3 V
4.1 V
3.9 V
386 U/min
570 U/min
206 U/min
244 U/min
1491 U/min
1411 U/min
36.6 CFM
+62.4 %
22.5 CFM
23.5 CFM
+18.4 %
19.9 CFM
23.9 CFM
+38.9 %
17.2 CFM
22.8 CFM
+35.8 %
16.8 CFM
62.2 m³/h
+62.4 %
38.3 m³/h
40.0 m³/h
+18.3 %
33.8 m³/h
39.8 m³/h
+35.8 %
29.3 m³/h
38.7 m³/h
+35.8 %
28.5 m³/h
1.12 mmH2O
+10.9 %
1.01 mmH2O
0.71
0.71
+16.4 %
+42.0 %
0.11 hPa
+11.1 %
+0.5 %
+16.0 %
+42.8 %
38.7
-4.9 %
36.8
37.9
-9.3 %
41.8
39.1
-3.5 %
40.5
37
-8.9 %
40.6
