Blacknoise
Lian Li
B12x-PS-BL PWM ARGB
UNI FAN SL120 ARGB
120 g
232 g
800 U/min
1500 U/min
1900 U/min
58.1 CFM
58.5 CFM
98.7 m³/h
99.5 m³/h
1.80 mmH2O
1.67 mmH2O
21.2 dBA
31.0 dBA
Silber
3.3 V
2.4 V
386 U/min
412 U/min
570 U/min
98 U/min
1491 U/min
1828 U/min
36.6 CFM
+57.5 %
23.2 CFM
23.5 CFM
+32.9 %
17.7 CFM
23.9 CFM
+51.3 %
15.8 CFM
22.8 CFM
+48.8 %
15.3 CFM
62.2 m³/h
+57.5 %
39.5 m³/h
40.0 m³/h
+32.9 %
30.1 m³/h
39.8 m³/h
+48.0 %
26.9 m³/h
38.7 m³/h
+48.8 %
26.0 m³/h
1.12 mmH2O
+180.0 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
0.11 hPa
+175.0 %
+75.0 %
+50.0 %
+75.0 %
38.7
-0.3 %
38.8
37.9
-3.2 %
36.7
39.1
-7.7 %
36.1
37
-6.5 %
34.6
