Blacknoise
Alphacool
B12x-PS-BL PWM ARGB
Eiszyklon Aurora Lux Pro ARGB
120 g
200 g
600 U/min
1500 U/min
1500 U/min
58.1 CFM
58.3 CFM
98.7 m³/h
99.3 m³/h
1.80 mmH2O
1.60 mmH2O
21.2 dBA
38.0 dBA
3.3 V
3.3 V
2.9 V
386 U/min
316 U/min
570 U/min
393 U/min
1491 U/min
1499 U/min
36.6 CFM
+25.6 %
46.0 CFM
23.5 CFM
+5.2 %
24.8 CFM
23.9 CFM
+13.1 %
21.2 CFM
22.8 CFM
+6.0 %
24.1 CFM
62.2 m³/h
+25.6 %
78.1 m³/h
40.0 m³/h
+5.3 %
42.1 m³/h
39.8 m³/h
+10.6 %
36.0 m³/h
38.7 m³/h
+5.9 %
41.0 m³/h
1.12 mmH2O
+57.7 %
+77.5 %
0.40 mmH2O
+22.0 %
+77.5 %
0.40 mmH2O
0.11 hPa
+57.1 %
+75.0 %
+20.0 %
+75.0 %
38.7
-11.1 %
34.4
37.9
-10.0 %
34.1
39.1
-15.3 %
33.1
37
-12.2 %
32.5
