Arctic
Alphacool
P12 PWM
Rise Aurora
139 g
180 g
200 U/min
1800 U/min
2500 U/min
56.3 CFM
70.0 CFM
118.9 m³/h
2.20 mmH2O
3.17 mmH2O
31.5 dBA
Silber
3.0 V
3.0 V
2.9 V
207 U/min
862 U/min
547 U/min
874 U/min
339 U/min
181 U/min
1748 U/min
2775 U/min
1045 U/min
33.5 CFM
+15.6 %
29.0 CFM
23.2 CFM
+5.1 %
24.4 CFM
23.0 CFM
+2.0 %
23.5 CFM
21.5 CFM
+2.5 %
22.1 CFM
57.0 m³/h
+15.6 %
49.3 m³/h
39.5 m³/h
+5.1 %
41.5 m³/h
39.1 m³/h
+2.0 %
39.9 m³/h
36.6 m³/h
+2.5 %
37.5 m³/h
+22.4 %
+19.6 %
0.51 mmH2O
+22.6 %
0.41 mmH2O
+49.5 %
0.41 mmH2O
+20.0 %
+20.0 %
+25.0 %
+50.0 %
36.7
-11.8 %
41.6
34.7
-15.4 %
41
34.7
-11.3 %
39.1
34.4
-15.1 %
40.5
