Cooler Master
Masterfan MF120 Halo
Silent Wings 3
180 g
137 g
650 U/min
150 U/min
1800 U/min
1450 U/min
47.2 CFM
50.5 CFM
85.8 m³/h
1.79 mmH2O
30.0 dBA
16.4 dBA
Grau
Halbtransparent
3.3 V
4.1 V
3.9 V
166 U/min
590 U/min
206 U/min
244 U/min
1792 U/min
1411 U/min
24.8 CFM
+9.9 %
22.5 CFM
19.89
19.89
20.2 CFM
+17.4 %
17.2 CFM
17.2 CFM
+2.8 %
16.8 CFM
42.1 m³/h
+9.9 %
38.3 m³/h
33.8
33.8
31.4 m³/h
+7.2 %
29.3 m³/h
29.3 m³/h
+2.8 %
28.5 m³/h
0.40 mmH2O
+152.5 %
1.01 mmH2O
+14.1 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+25.0 %
+147.6 %
+14.9 %
+74.1 %
+22.6 %
37.8
-2.6 %
36.8
36.4
-12.9 %
41.8
36.5
-9.9 %
40.5
35.6
-12.3 %
40.6
