Cooler Master
Cooler Master
Masterfan MF120 Halo
Sickleflow 140 ARGB
180 g
195 g
650 U/min
650 U/min
1800 U/min
1400 U/min
47.2 CFM
67.0 CFM
113.8 m³/h
2.25 mmH2O
30.0 dBA
27.0 dBA
Grau
Halbtransparent
Halbtransparent
3.3 V
5.5 V
2.9 V
166 U/min
599 U/min
590 U/min
495 U/min
1792 U/min
1374 U/min
24.8 CFM
+83.0 %
45.3 CFM
19.9 CFM
+41.1 %
28.1 CFM
20.2 CFM
+28.8 %
26.1 CFM
17.2 CFM
+56.7 %
27.0 CFM
42.1 m³/h
+82.9 %
77.0 m³/h
33.8 m³/h
+41.1 %
47.7 m³/h
31.4 m³/h
+41.1 %
44.3 m³/h
29.3 m³/h
+56.7 %
45.9 m³/h
0.40 mmH2O
+25.0 %
+62.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+25.0 %
+60.0 %
+25.0 %
+25.0 %
37.8
-6.1 %
35.5
36.4
-2.2 %
37.2
36.5
-10.1 %
32.8
35.6
-5.9 %
33.5
