Corsair
Noctua
ML 120 RGB Elite
NF-A14 FLX
186 g
210 g
450 U/min
900 U/min
1200 U/min
1.6 W
58.1 CFM
68.0 CFM
98.7 m³/h
115.5 m³/h
2.90 mmH2O
1.51 mmH2O
30.4 dBA
19.2 dBA
Beige
Braun
Braun
3.0 V
4.6 V
4.2 V
510 U/min
381 U/min
450 U/min
469 U/min
169 U/min
84 U/min
1993 U/min
1199 U/min
35.2 CFM
+51.8 %
53.5 CFM
24.2 CFM
+36.3 %
33.0 CFM
23.7 CFM
+33.6 %
31.7 CFM
21.3 CFM
+41.5 %
30.1 CFM
59.9 m³/h
+51.8 %
90.9 m³/h
41.1 m³/h
+36.3 %
56.0 m³/h
40.3 m³/h
+33.5 %
53.8 m³/h
36.2 m³/h
+41.4 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+49.2 %
0.91 mmH2O
+22.0 %
+136.7 %
0.30 mmH2O
+28.6 %
0.09 hPa
+50.0 %
0.09 hPa
+20.0 %
+133.3 %
0.03 hPa
28.5
-16.7 %
34.2
29.5
-30.8 %
42.6
28.5
-30.1 %
40.8
27.8
-30.3 %
39.9
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
