Corsair
Sharkoon
QL120 RGB
Silent Storm PWM RGB Fan
163 g
168 g
500 U/min
400 U/min
1500 U/min
1400 U/min
2.6 W
41.8 CFM
121.9 m³/h
1.55 mmH2O
1.47 mmH2O
26.0 dBA
34.7 dBA
Silber
Halbtransparent
3.0 V
1.9 V
245 U/min
506 U/min
472 U/min
54 U/min
1600 U/min
1413 U/min
440 U/min
27.8 CFM
+47.9 %
41.1 CFM
20.6 CFM
+55.1 %
31.9 CFM
19.2 CFM
+59.9 %
30.7 CFM
17.2 CFM
+94.9 %
33.6 CFM
47.2 m³/h
+47.9 %
69.8 m³/h
35.0 m³/h
+55.1 %
54.3 m³/h
32.6 m³/h
+59.8 %
52.1 m³/h
29.3 m³/h
+94.9 %
57.1 m³/h
1.01 mmH2O
+24.7 %
+42.0 %
+42.0 %
0.40 mmH2O
+27.5 %
0.51 mmH2O
+25.0 %
+40.0 %
+40.0 %
+25.0 %
38.4
-15.1 %
32.6
38.3
-14.6 %
32.7
35.9
-7.5 %
33.2
35.8
-10.3 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
