Corsair
Corsair
QL120 RGB
ML 120 RGB Elite
163 g
186 g
500 U/min
450 U/min
1500 U/min
1.6 W
41.8 CFM
58.1 CFM
98.7 m³/h
1.55 mmH2O
2.90 mmH2O
26.0 dBA
30.4 dBA
Silber
Halbtransparent
3.0 V
3.0 V
245 U/min
510 U/min
472 U/min
450 U/min
169 U/min
84 U/min
1600 U/min
1993 U/min
27.8 CFM
+26.9 %
35.2 CFM
20.6 CFM
+17.4 %
24.2 CFM
19.2 CFM
+23.6 %
23.7 CFM
17.2 CFM
+23.5 %
21.3 CFM
47.2 m³/h
+26.9 %
59.9 m³/h
35.0 m³/h
+17.4 %
41.1 m³/h
32.6 m³/h
+23.6 %
40.3 m³/h
29.3 m³/h
+23.5 %
36.2 m³/h
1.01 mmH2O
+42.3 %
+22.0 %
+22.0 %
0.40 mmH2O
+77.5 %
+42.9 %
+20.0 %
+20.0 %
+75.0 %
38.4
-25.8 %
28.5
38.3
-23.0 %
29.5
35.9
-20.6 %
28.5
35.8
-22.3 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
