Corsair
Fractal
QL120 RGB
Prisma AL-12PWM
163 g
167 g
500 U/min
500 U/min
1500 U/min
1.9 W
41.8 CFM
85.7 CFM
145.7 m³/h
1.55 mmH2O
2.80 mmH2O
26.0 dBA
32.0 dBA
Silber
Halbtransparent
3.0 V
4.5 V
3.8 V
245 U/min
443 U/min
472 U/min
269 U/min
1600 U/min
2001 U/min
550 U/min
27.8 CFM
+13.8 %
31.6 CFM
20.6 CFM
+0.5 %
20.7 CFM
19.2 CFM
+8.6 %
20.8 CFM
17.2 CFM
+14.7 %
19.8 CFM
47.2 m³/h
+13.8 %
53.7 m³/h
35.0 m³/h
+0.6 %
35.2 m³/h
32.6 m³/h
+8.6 %
35.4 m³/h
29.3 m³/h
+14.7 %
33.6 m³/h
1.01 mmH2O
+24.7 %
+42.0 %
+42.0 %
0.40 mmH2O
+52.5 %
+25.0 %
+40.0 %
+40.0 %
+50.0 %
38.4
-7.6 %
35.5
38.3
-12.3 %
33.6
35.9
-11.1 %
31.9
35.8
-20.1 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
