Corsair
QL120 RGB
Light Wings 140 PWM HS
163 g
266 g
500 U/min
250 U/min
1500 U/min
2200 U/min
1.9 W
4.7 W
41.8 CFM
71.7 CFM
121.8 m³/h
1.55 mmH2O
2.30 mmH2O
26.0 dBA
31.0 dBA
Silber
Halbtransparent
3.0 V
3.0 V
245 U/min
565 U/min
472 U/min
556 U/min
1600 U/min
2264 U/min
241 U/min
27.8 CFM
+44.5 %
40.1 CFM
20.6 CFM
+18.5 %
24.4 CFM
19.2 CFM
+17.2 %
22.5 CFM
17.2 CFM
+40.0 %
24.1 CFM
47.2 m³/h
+44.5 %
68.2 m³/h
35.0 m³/h
+18.6 %
41.5 m³/h
32.6 m³/h
+17.2 %
38.2 m³/h
29.3 m³/h
+39.9 %
41.0 m³/h
1.01 mmH2O
+81.2 %
1.83 mmH2O
+22.0 %
+22.0 %
0.40 mmH2O
+52.5 %
+80.0 %
0.18 hPa
+20.0 %
+20.0 %
+50.0 %
38.4
-33.6 %
25.5
38.3
-30.3 %
26.7
35.9
-28.4 %
25.7
35.8
-28.8 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
