Corsair
QL120 RGB
Light Wings PWM HS
163 g
210 g
500 U/min
300 U/min
1500 U/min
2500 U/min
1.4 W
5.4 W
41.8 CFM
52.3 CFM
88.9 m³/h
1.55 mmH2O
2.60 mmH2O
26.0 dBA
31.0 dBA
Silber
Halbtransparent
3.0 V
245 U/min
608 U/min
472 U/min
565 U/min
1600 U/min
2489 U/min
248 U/min
27.8 CFM
+17.1 %
32.5 CFM
20.6 CFM
+11.5 %
18.5 CFM
19.2 CFM
+1.2 %
18.9 CFM
17.2 CFM
+2.7 %
17.7 CFM
47.2 m³/h
+17.2 %
55.3 m³/h
35.0 m³/h
+11.5 %
31.4 m³/h
32.6 m³/h
+1.2 %
32.2 m³/h
29.3 m³/h
+2.7 %
30.1 m³/h
1.01 mmH2O
+42.3 %
0.5
0.5
+25.0 %
0.40 mmH2O
0.40 mmH2O
+25.0 %
+42.9 %
0.05
0.05
+25.0 %
+25.0 %
38.4
-12.2 %
33.7
38.3
-17.5 %
31.6
35.9
-10.9 %
32
35.8
-14.2 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
