Corsair
QL120 RGB
Silent Wings 3
163 g
137 g
500 U/min
150 U/min
1500 U/min
1450 U/min
41.8 CFM
50.5 CFM
85.8 m³/h
1.55 mmH2O
1.79 mmH2O
26.0 dBA
16.4 dBA
Silber
Halbtransparent
3.0 V
4.1 V
3.9 V
245 U/min
472 U/min
206 U/min
244 U/min
1600 U/min
1411 U/min
27.8 CFM
+23.2 %
22.5 CFM
20.6 CFM
+3.6 %
19.9 CFM
19.2 CFM
+11.3 %
17.2 CFM
17.2 CFM
+2.8 %
16.8 CFM
47.2 m³/h
+23.2 %
38.3 m³/h
35.0 m³/h
+3.6 %
33.8 m³/h
32.6 m³/h
+11.3 %
29.3 m³/h
29.3 m³/h
+2.8 %
28.5 m³/h
1.01
1.01
+42.0 %
+42.0 %
0.40 mmH2O
+25.0 %
+1.0 %
+39.3 %
+39.3 %
+22.6 %
38.4
-4.2 %
36.8
38.3
-8.4 %
41.8
35.9
-11.4 %
40.5
35.8
-11.8 %
40.6
