Corsair
Lian Li
QL120 RGB
UNI FAN SL120 ARGB
163 g
232 g
500 U/min
800 U/min
1500 U/min
1900 U/min
41.8 CFM
58.5 CFM
99.5 m³/h
1.55 mmH2O
1.67 mmH2O
26.0 dBA
31.0 dBA
Silber
Silber
Halbtransparent
3.0 V
2.4 V
245 U/min
412 U/min
472 U/min
98 U/min
1600 U/min
1828 U/min
27.8 CFM
+19.5 %
23.2 CFM
20.6 CFM
+16.3 %
17.7 CFM
19.2 CFM
+21.2 %
15.8 CFM
17.2 CFM
+12.7 %
15.3 CFM
47.2 m³/h
+19.5 %
39.5 m³/h
35.0 m³/h
+16.3 %
30.1 m³/h
32.6 m³/h
+21.2 %
26.9 m³/h
29.3 m³/h
+12.7 %
26.0 m³/h
1.01 mmH2O
+152.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.4
0.4
+150.0 %
+25.0 %
+25.0 %
0.04
0.04
38.4
-1.0 %
38.8
38.3
-4.2 %
36.7
35.9
-0.6 %
36.1
35.8
-3.4 %
34.6
