Corsair
Arctic
QL120 RGB
P14 PWM
163 g
194 g
500 U/min
200 U/min
1500 U/min
1700 U/min
41.8 CFM
72.8 CFM
123.8 m³/h
1.55 mmH2O
2.40 mmH2O
26.0 dBA
Silber
Halbtransparent
3.0 V
3.8 V
245 U/min
395 U/min
472 U/min
481 U/min
1600 U/min
1733 U/min
27.8 CFM
+64.4 %
45.7 CFM
20.6 CFM
+31.4 %
27.1 CFM
19.2 CFM
+34.4 %
25.8 CFM
17.2 CFM
+56.7 %
27.0 CFM
47.2 m³/h
+64.4 %
77.6 m³/h
35.0 m³/h
+31.4 %
46.0 m³/h
32.6 m³/h
+34.4 %
43.8 m³/h
29.3 m³/h
+56.7 %
45.9 m³/h
1.01 mmH2O
+68.3 %
0.60 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.4
0.4
+66.7 %
+25.0 %
+25.0 %
0.04
0.04
38.4
-20.1 %
30.7
38.3
-20.6 %
30.4
35.9
-16.4 %
30
35.8
-14.5 %
30.6
