Lian Li
Asus
UNI FAN SL120 ARGB
232 g
145 g
800 U/min
250 U/min
1900 U/min
1800 U/min
58.5 CFM
62.5 CFM
99.5 m³/h
106.2 m³/h
1.67 mmH2O
3.07 mmH2O
31.0 dBA
22.5 dBA
Silber
2.4 V
412 U/min
409 U/min
98 U/min
419 U/min
208 U/min
129 U/min
1828 U/min
1778 U/min
308 U/min
23.2 CFM
+3.1 %
23.9 CFM
17.7 CFM
+5.6 %
18.7 CFM
15.8 CFM
+16.7 %
18.5 CFM
15.3 CFM
+15.8 %
17.7 CFM
39.5 m³/h
+3.0 %
40.7 m³/h
30.1 m³/h
+5.6 %
31.8 m³/h
26.9 m³/h
+16.7 %
31.4 m³/h
26.0 m³/h
+15.8 %
30.1 m³/h
0.40 mmH2O
+129.4 %
0.92 mmH2O
0.40 mmH2O
+129.4 %
0.92 mmH2O
0.40 mmH2O
+103.9 %
0.82 mmH2O
0.40 mmH2O
+78.5 %
+125.0 %
0.09 hPa
+125.0 %
0.09 hPa
+100.0 %
+75.0 %
38.8
-10.8 %
34.6
36.7
-5.7 %
38.9
36.1
-6.0 %
38.4
34.6
-9.9 %
38.4
