Arctic
P14 PWM
Silent Wings 3
194 g
137 g
200 U/min
150 U/min
1700 U/min
1450 U/min
72.8 CFM
50.5 CFM
123.8 m³/h
85.8 m³/h
2.40 mmH2O
1.79 mmH2O
16.4 dBA
3.8 V
4.1 V
3.9 V
395 U/min
481 U/min
206 U/min
244 U/min
1733 U/min
1411 U/min
45.7 CFM
+102.6 %
22.5 CFM
27.1 CFM
+36.1 %
19.9 CFM
25.8 CFM
+49.5 %
17.2 CFM
27.0 CFM
+61.1 %
16.8 CFM
77.6 m³/h
+102.6 %
38.3 m³/h
46.0 m³/h
+36.1 %
33.8 m³/h
43.8 m³/h
+49.5 %
29.3 m³/h
45.9 m³/h
+61.1 %
28.5 m³/h
0.60 mmH2O
+68.3 %
1.01 mmH2O
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+25.0 %
+65.1 %
+74.1 %
+74.1 %
+22.6 %
30.7
-16.6 %
36.8
30.4
-27.3 %
41.8
30
-25.9 %
40.5
30.6
-24.6 %
40.6
