Corsair
MSI
LL140 RGB
MEG Silent Gale P12
27.5 mm
210 g
209 g
600 U/min
1300 U/min
0.7 W
1.4 W
51.5 CFM
56.2 CFM
87.5 m³/h
95.5 m³/h
1.52 mmH2O
2.21 mmH2O
25.0 dBA
22.7 dBA
Halbtransparent
5.5 V
2.9 V
4.3 V
226 U/min
906 U/min
378 U/min
742 U/min
194 U/min
186 U/min
1319 U/min
1980 U/min
512 U/min
45.0 CFM
+44.6 %
31.1 CFM
28.4 CFM
+31.7 %
21.5 CFM
24.5 CFM
+10.9 %
22.1 CFM
26.4 CFM
+34.3 %
19.7 CFM
76.5 m³/h
+44.6 %
52.9 m³/h
48.2 m³/h
+31.7 %
36.6 m³/h
41.6 m³/h
+10.9 %
37.5 m³/h
44.9 m³/h
+34.4 %
33.4 m³/h
0.60 mmH2O
+51.7 %
0.91 mmH2O
+62.0 %
+62.0 %
+32.8 %
+50.0 %
0.09 hPa
+60.0 %
+60.0 %
+33.3 %
35.3
-11.6 %
31.2
36.9
-5.7 %
34.8
34
-1.7 %
34.6
34.8
-4.9 %
33.1
