Corsair
Alphacool
LL140 RGB
Rise Aurora
210 g
180 g
600 U/min
1300 U/min
2500 U/min
51.5 CFM
70.0 CFM
87.5 m³/h
118.9 m³/h
1.52 mmH2O
3.17 mmH2O
25.0 dBA
31.5 dBA
Halbtransparent
3.0 V
2.9 V
2.9 V
226 U/min
862 U/min
378 U/min
874 U/min
339 U/min
181 U/min
1319 U/min
2775 U/min
1045 U/min
45.0 CFM
+55.2 %
29.0 CFM
28.4 CFM
+16.2 %
24.4 CFM
24.5 CFM
+4.3 %
23.5 CFM
26.4 CFM
+19.7 %
22.1 CFM
76.5 m³/h
+55.2 %
49.3 m³/h
48.2 m³/h
+16.1 %
41.5 m³/h
41.6 m³/h
+4.3 %
39.9 m³/h
44.9 m³/h
+19.7 %
37.5 m³/h
0.60 mmH2O
+2.0 %
+2.0 %
0.51 mmH2O
+22.6 %
0.41 mmH2O
+49.5 %
0.41 mmH2O
0.06
0.06
0.05
0.05
+25.0 %
+50.0 %
35.3
-15.1 %
41.6
36.9
-10.0 %
41
34
-13.0 %
39.1
34.8
-14.1 %
40.5
