Corsair
LL140 RGB
Silent Wings 3
210 g
137 g
600 U/min
150 U/min
1300 U/min
1450 U/min
51.5 CFM
50.5 CFM
87.5 m³/h
85.8 m³/h
1.52 mmH2O
1.79 mmH2O
25.0 dBA
16.4 dBA
Halbtransparent
4.1 V
2.9 V
3.9 V
226 U/min
378 U/min
206 U/min
244 U/min
1319 U/min
1411 U/min
45.0 CFM
+99.8 %
22.5 CFM
28.4 CFM
+42.6 %
19.9 CFM
24.5 CFM
+42.0 %
17.2 CFM
26.4 CFM
+57.6 %
16.8 CFM
76.5 m³/h
+99.7 %
38.3 m³/h
48.2 m³/h
+42.6 %
33.8 m³/h
41.6 m³/h
+42.0 %
29.3 m³/h
44.9 m³/h
+57.5 %
28.5 m³/h
0.60 mmH2O
+68.3 %
1.01 mmH2O
+42.0 %
+42.0 %
+22.0 %
+65.1 %
+39.3 %
+39.3 %
+22.4 %
35.3
-4.1 %
36.8
36.9
-11.7 %
41.8
34
-16.0 %
40.5
34.8
-14.3 %
40.6
