Corsair
Noctua
LL140 RGB
NF-A14 FLX
210 g
210 g
600 U/min
900 U/min
1300 U/min
1200 U/min
51.5 CFM
68.0 CFM
87.5 m³/h
115.5 m³/h
1.52 mmH2O
1.51 mmH2O
25.0 dBA
19.2 dBA
Beige
Braun
Halbtransparent
Braun
4.6 V
2.9 V
4.2 V
226 U/min
381 U/min
378 U/min
469 U/min
1319 U/min
1199 U/min
45.0 CFM
+18.8 %
53.5 CFM
28.4 CFM
+16.2 %
33.0 CFM
24.5 CFM
+29.3 %
31.7 CFM
26.4 CFM
+14.0 %
30.1 CFM
76.5 m³/h
+18.8 %
90.9 m³/h
48.2 m³/h
+16.2 %
56.0 m³/h
41.6 m³/h
+29.3 %
53.8 m³/h
44.9 m³/h
+14.0 %
51.2 m³/h
0.60 mmH2O
+51.7 %
0.91 mmH2O
+82.0 %
0.91 mmH2O
0.5
0.5
+103.3 %
0.30 mmH2O
+50.0 %
0.09 hPa
+80.0 %
0.09 hPa
0.05
0.05
+100.0 %
0.03 hPa
35.3
-3.1 %
34.2
36.9
-13.4 %
42.6
34
-16.7 %
40.8
34.8
-12.8 %
39.9
