Corsair
Thermaltake
LL140 RGB
210 g
212 g
600 U/min
500 U/min
1300 U/min
51.5 CFM
58.4 CFM
87.5 m³/h
99.1 m³/h
1.52 mmH2O
2.41 mmH2O
25.0 dBA
22.3 dBA
Grau
Halbtransparent
2.9 V
226 U/min
391 U/min
378 U/min
413 U/min
1319 U/min
1950 U/min
45.0 CFM
+35.7 %
33.2 CFM
28.4 CFM
+12.6 %
25.2 CFM
24.5 CFM
+0.0 %
24.5 CFM
26.4 CFM
+26.9 %
20.8 CFM
76.5 m³/h
+35.7 %
56.4 m³/h
48.2 m³/h
+12.6 %
42.8 m³/h
41.6 m³/h
+0.0 %
41.6 m³/h
44.9 m³/h
+26.9 %
35.4 m³/h
0.60 mmH2O
+206.7 %
1.84 mmH2O
+62.0 %
0.5
0.5
+52.5 %
0.40 mmH2O
+200.7 %
0.18 hPa
+58.9 %
+2.0 %
+53.0 %
35.3
-5.6 %
37.4
36.9
-1.1 %
36.5
34
-5.6 %
36
34.8
-3.9 %
36.2
