Alphacool
NZXT
Eiszyklon Aurora Lux Pro ARGB
F120 RGB
26 mm
200 g
205 g
600 U/min
500 U/min
1500 U/min
1800 U/min
0.4 W
1.8 W
58.3 CFM
50.2 CFM
99.3 m³/h
85.2 m³/h
1.60 mmH2O
2.70 mmH2O
38.0 dBA
27.5 dBA
3.3 V
4.7 V
2.9 V
4.4 V
316 U/min
827 U/min
393 U/min
703 U/min
1499 U/min
1924 U/min
447 U/min
46.0 CFM
+90.0 %
24.2 CFM
24.8 CFM
+30.7 %
18.9 CFM
21.2 CFM
+62.9 %
13.0 CFM
24.1 CFM
+29.0 %
18.7 CFM
78.1 m³/h
+90.0 %
41.1 m³/h
42.1 m³/h
+30.7 %
32.2 m³/h
36.0 m³/h
+62.9 %
22.1 m³/h
41.0 m³/h
+28.9 %
31.8 m³/h
+28.2 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
+62.0 %
0.40 mmH2O
+102.5 %
+28.6 %
0.09 hPa
+100.0 %
+60.0 %
+100.0 %
34.4
-27.9 %
24.8
34.1
-10.9 %
30.4
33.1
-2.1 %
32.4
32.5
-8.9 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
