Noctua
Lian Li
NF-A14 FLX
UNI FAN SL-INF 120
210 g
210 g
900 U/min
1200 U/min
2100 U/min
3.0 W
68.0 CFM
61.3 CFM
115.5 m³/h
104.1 m³/h
1.51 mmH2O
2.66 mmH2O
19.2 dBA
29.0 dBA
Beige
Braun
Braun
4.6 V
3.5 V
4.2 V
381 U/min
913 U/min
469 U/min
742 U/min
290 U/min
298 U/min
1199 U/min
2134 U/min
886 U/min
53.5 CFM
+78.6 %
30.0 CFM
33.0 CFM
+38.3 %
23.8 CFM
31.7 CFM
+47.0 %
21.5 CFM
30.1 CFM
+35.1 %
22.3 CFM
90.9 m³/h
+78.6 %
50.9 m³/h
56.0 m³/h
+38.3 %
40.5 m³/h
53.8 m³/h
+47.0 %
36.6 m³/h
51.2 m³/h
+35.1 %
37.9 m³/h
0.91 mmH2O
+28.2 %
0.91 mmH2O
+28.2 %
+2.0 %
0.51 mmH2O
0.30 mmH2O
+70.0 %
0.51 mmH2O
0.09 hPa
+29.3 %
0.09 hPa
+29.3 %
+0.0 %
0.03 hPa
+66.7 %
34.2
-4.7 %
32.6
42.6
-21.4 %
33.5
40.8
-20.1 %
32.6
39.9
-16.0 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
