Noctua
Sharkoon
NF-A14 FLX
Silent Storm PWM RGB Fan
210 g
168 g
900 U/min
400 U/min
1200 U/min
1400 U/min
2.6 W
68.0 CFM
115.5 m³/h
121.9 m³/h
1.51 mmH2O
1.47 mmH2O
19.2 dBA
34.7 dBA
Beige
Braun
Braun
4.6 V
4.2 V
1.9 V
381 U/min
506 U/min
469 U/min
54 U/min
1199 U/min
1413 U/min
440 U/min
53.5 CFM
+30.2 %
41.1 CFM
33.0 CFM
+3.2 %
31.9 CFM
31.7 CFM
+3.3 %
30.7 CFM
30.1 CFM
+11.5 %
33.6 CFM
90.9 m³/h
+30.2 %
69.8 m³/h
56.0 m³/h
+3.1 %
54.3 m³/h
53.8 m³/h
+3.3 %
52.1 m³/h
51.2 m³/h
+11.5 %
57.1 m³/h
0.91 mmH2O
+12.3 %
0.91 mmH2O
+28.2 %
+42.0 %
0.30 mmH2O
+70.0 %
0.51 mmH2O
0.09 hPa
+12.5 %
0.09 hPa
+28.6 %
+40.0 %
0.03 hPa
+66.7 %
34.2
-4.7 %
32.6
42.6
-23.2 %
32.7
40.8
-18.6 %
33.2
39.9
-19.5 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
