Noctua
Arctic
NF-A14 FLX
P14 PWM
210 g
194 g
900 U/min
200 U/min
1200 U/min
1700 U/min
68.0 CFM
72.8 CFM
115.5 m³/h
123.8 m³/h
1.51 mmH2O
2.40 mmH2O
19.2 dBA
Beige
Braun
Braun
4.6 V
3.8 V
4.2 V
381 U/min
395 U/min
469 U/min
481 U/min
1199 U/min
1733 U/min
53.5 CFM
+17.1 %
45.7 CFM
33.0 CFM
+21.8 %
27.1 CFM
31.7 CFM
+22.9 %
25.8 CFM
30.1 CFM
+11.6 %
27.0 CFM
90.9 m³/h
+17.1 %
77.6 m³/h
56.0 m³/h
+21.7 %
46.0 m³/h
53.8 m³/h
+22.8 %
43.8 m³/h
51.2 m³/h
+11.5 %
45.9 m³/h
0.91 mmH2O
+51.7 %
0.60 mmH2O
0.91 mmH2O
+127.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.30 mmH2O
+33.3 %
0.40 mmH2O
0.09 hPa
+50.0 %
0.09 hPa
+125.0 %
+25.0 %
0.03 hPa
+33.3 %
34.2
-10.2 %
30.7
42.6
-28.6 %
30.4
40.8
-26.5 %
30
39.9
-23.3 %
30.6
