Thermaltake
Cooler Master
Sickleflow 140 ARGB
212 g
195 g
500 U/min
650 U/min
1400 U/min
58.4 CFM
67.0 CFM
99.1 m³/h
113.8 m³/h
2.41 mmH2O
2.25 mmH2O
22.3 dBA
27.0 dBA
Grau
Halbtransparent
5.5 V
2.9 V
391 U/min
599 U/min
413 U/min
495 U/min
1950 U/min
1374 U/min
33.2 CFM
+36.5 %
45.3 CFM
25.2 CFM
+11.4 %
28.1 CFM
24.5 CFM
+6.5 %
26.1 CFM
20.8 CFM
+29.7 %
27.0 CFM
56.4 m³/h
+36.5 %
77.0 m³/h
42.8 m³/h
+11.5 %
47.7 m³/h
41.6 m³/h
+6.5 %
44.3 m³/h
35.4 m³/h
+29.7 %
45.9 m³/h
1.84 mmH2O
+268.0 %
+62.0 %
0.5
0.5
0.40 mmH2O
+25.0 %
0.18 hPa
+260.9 %
+58.9 %
+2.0 %
+27.5 %
37.4
-5.1 %
35.5
36.5
-1.9 %
37.2
36
-8.9 %
32.8
36.2
-7.5 %
33.5
