Thermaltake
Noctua
NF-A14 FLX
212 g
210 g
500 U/min
900 U/min
1200 U/min
58.4 CFM
68.0 CFM
99.1 m³/h
115.5 m³/h
2.41 mmH2O
1.51 mmH2O
22.3 dBA
19.2 dBA
Beige
Grau
Braun
Braun
4.6 V
4.2 V
391 U/min
381 U/min
413 U/min
469 U/min
1950 U/min
1199 U/min
33.2 CFM
+61.2 %
53.5 CFM
25.2 CFM
+30.8 %
33.0 CFM
24.5 CFM
+29.4 %
31.7 CFM
20.8 CFM
+44.7 %
30.1 CFM
56.4 m³/h
+61.2 %
90.9 m³/h
42.8 m³/h
+30.8 %
56.0 m³/h
41.6 m³/h
+29.4 %
53.8 m³/h
35.4 m³/h
+44.7 %
51.2 m³/h
1.84 mmH2O
+102.2 %
0.91 mmH2O
+12.3 %
0.91 mmH2O
0.5
0.5
0.40 mmH2O
+33.3 %
0.30 mmH2O
0.18 hPa
+100.5 %
0.09 hPa
+13.3 %
0.09 hPa
+2.0 %
+30.8 %
0.03 hPa
37.4
-8.6 %
34.2
36.5
-14.3 %
42.6
36
-11.8 %
40.8
36.2
-9.3 %
39.9
