Here you can find all fans that have been tested so far and you can search for them individually or combined based on various features. Additionally, the tables can be sorted in ascending or descending order according to their properties. For each individual fan, there is also a detailed view with all recorded and measured data, including sound samples and precise frequency analyses. You can find the relevant button for the methodology and equipment in the menu above, leading to an extra page that can be opened in a new window or tab.
Beta phase: The same applies during the beta phase, where the limitations with interpolated and restricted data from the older, initial fan tests are still in place, but we will gradually complete them over time. Any errors in the software or data entry, we ask you to forgive, and we will make the necessary adjustments as soon as possible. Please send suggestions and feedback exclusively via email to [email protected].
The fans tested here were either provided by the manufacturers without preconditions or come from the editorial stock or were anonymously purchased in stores. None of the tests were influenced in any way by the respective manufacturer. The test results were communicated to the manufacturers for review and comment in advance in case of abnormalities or strong contradictions to the stated technical data, and in some cases, measurements were also taken with anonymously purchased retail goods.
We explicitly point out that our laboratory cannot and does not want to produce ISO-certified measurements. The test setups with and without radiators were designed by us to be as practical as possible, in order to capture all intermediate values in the respective speed ranges. The audio recordings were normalized to also transport the smallest nuances into the audible ranges. Therefore, it may well happen that the fans seemed louder than they are. For a comparison of the absolute noise emission of two fans, the measurement curve must always be compared.
The manufacturer information used comes either from the respective packaging or from the data sheets on the respective homepages of the providers. Since we have already found several printing errors and even completely incorrect information, these values should always be viewed with the necessary skepticism if they significantly deviate from our measurements. Moreover, more than once a product has been significantly changed over time without this being publicly communicated. In this case, we ask our readers for appropriate feedback if new contradictions arise.
Cookie-Zustimmung verwalten
Wir verwenden Technologien wie Cookies, um Geräteinformationen zu speichern und/oder darauf zuzugreifen. Wir tun dies, um das Surferlebnis zu verbessern und um personalisierte Werbung anzuzeigen. Wenn Sie diesen Technologien zustimmen, können wir Daten wie das Surfverhalten oder eindeutige IDs auf dieser Website verarbeiten. Wenn Sie Ihre Zustimmung nicht erteilen oder zurückziehen, können bestimmte Funktionen beeinträchtigt werden.
Funktional
Always active
Die technische Speicherung oder der Zugang ist unbedingt erforderlich für den rechtmäßigen Zweck, die Nutzung eines bestimmten Dienstes zu ermöglichen, der vom Teilnehmer oder Nutzer ausdrücklich gewünscht wird, oder für den alleinigen Zweck, die Übertragung einer Nachricht über ein elektronisches Kommunikationsnetz durchzuführen.
Vorlieben
Die technische Speicherung oder der Zugriff ist für den rechtmäßigen Zweck der Speicherung von Präferenzen erforderlich, die nicht vom Abonnenten oder Benutzer angefordert wurden.
Statistiken
Die technische Speicherung oder der Zugriff, der ausschließlich zu statistischen Zwecken erfolgt.Die technische Speicherung oder der Zugriff, der ausschließlich zu anonymen statistischen Zwecken verwendet wird. Ohne eine Vorladung, die freiwillige Zustimmung deines Internetdienstanbieters oder zusätzliche Aufzeichnungen von Dritten können die zu diesem Zweck gespeicherten oder abgerufenen Informationen allein in der Regel nicht dazu verwendet werden, dich zu identifizieren.
Marketing
Die technische Speicherung oder der Zugriff ist erforderlich, um Nutzerprofile zu erstellen, um Werbung zu versenden oder um den Nutzer auf einer Website oder über mehrere Websites hinweg zu ähnlichen Marketingzwecken zu verfolgen.
