Arctic
Asus
P12 PWM PST RGB 0dB
159 g
145 g
250 U/min
1800 U/min
48.8 CFM
62.5 CFM
82.9 m³/h
106.2 m³/h
1.85 mmH2O
3.07 mmH2O
22.5 dBA
Grau
Halbtransparent
4.0 V
2.9 V
380 U/min
409 U/min
532 U/min
419 U/min
208 U/min
129 U/min
1985 U/min
1778 U/min
308 U/min
32.1 CFM
+34.2 %
23.9 CFM
23.9 CFM
+28.0 %
18.7 CFM
23.0 CFM
+24.5 %
18.5 CFM
22.1 CFM
+24.6 %
17.7 CFM
54.6 m³/h
+34.1 %
40.7 m³/h
40.7 m³/h
+28.0 %
31.8 m³/h
39.1 m³/h
+24.5 %
31.4 m³/h
37.5 m³/h
+24.6 %
30.1 m³/h
+13.3 %
0.92 mmH2O
+50.5 %
0.92 mmH2O
+33.7 %
0.82 mmH2O
+17.0 %
+12.5 %
0.09 hPa
+50.0 %
0.09 hPa
+33.3 %
+16.7 %
33.8
-2.3 %
34.6
31.6
-18.8 %
38.9
32.7
-14.8 %
38.4
32.1
-16.4 %
38.4
