Blacknoise
Sharkoon
B12x-PS-BL PWM ARGB
Silent Storm PWM RGB Fan
120 g
135 g
400 U/min
1500 U/min
1400 U/min
2.2 W
58.1 CFM
98.7 m³/h
93.6 m³/h
1.80 mmH2O
21.2 dBA
20.4 dBA
3.3 V
3.6 V
386 U/min
585 U/min
570 U/min
561 U/min
1491 U/min
1374 U/min
513 U/min
36.6 CFM
+7.6 %
34.0 CFM
23.5 CFM
+20.8 %
19.5 CFM
23.9 CFM
+2.0 %
24.4 CFM
22.8 CFM
+5.7 %
21.5 CFM
62.2 m³/h
+7.6 %
57.8 m³/h
40.0 m³/h
+20.8 %
33.1 m³/h
39.8 m³/h
+4.3 %
41.5 m³/h
38.7 m³/h
+5.7 %
36.6 m³/h
1.12 mmH2O
+57.7 %
+16.4 %
0.61
0.61
+16.4 %
0.11 hPa
+57.1 %
+16.7 %
0.06
0.06
+16.7 %
38.7
-18.1 %
31.7
37.9
-23.0 %
29.2
39.1
-29.7 %
27.5
37
-26.8 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
